2.8 change cam plug w/o removing valve cover?
I am the proud owner of a Leaking Right Rear cam plug. Is it possible to dig this out and tap a new one in without removing the valve cover and splitting the aluminum halves?
I tried last week to get mine out.Could not, it has small grooves that match the cam halves.Bentley manual was of no help here other than showing the need of a special tool to remove the seal. Tool 3420 extractor. Torque for the cam caps is 15 ft lbs per Bentley.7 ft lbs for valve cover. Cam seals should not be oiled. Good luck.
Consider pulling the valve covers and either loosening (others) or removing (what I did) the cams to make the job cake. They sell the gaskets in kits for a reason, since they do tend to go south near the same time (cam,valve cover and tensioner seals). Get a manual for cam alignment, torque specs and procedures. Tightening sequence for the cam caps and covers is important.
There is a tech article for the 2.7 that may be of some help. It has pics of places to be aware of. I think there used to be a tech article for the 2.8 but you can probably dig it up from the archives.
What viscosity oil are you running? I have always used dino here in CA. 5w-30 weeps a little. 10w-30 bone dry.
Also take a peek at your suction pump (see tech article). If it's clogged (look for oil residue near the hose connections), there might be some overpressure under the covers helping to force oil out the seals.
Keep thinking about other ?'s for you. I have the same issue right now. Oil leaking from plug and cam cover gasket on to manifold, and the infamous oil smell in the cabin. Is the plug metal or plastic? No leak after installation?
Thanks
Thanks
BikerBill
02-09-2012 03:28 PM
Canon
03-30-2007 05:51 AM
