2.8L V6 99.5 Multiple Cylinder Misfire Detected (mostly on cyl 4 and cyl 5)
Car is: 99.5 A4 2.8 V6 Quattro
Little info:
*Spark plugs NGK BKR6EIX Iridium IX (almost new june2013 ~9k on it)
*BERU Spark plug wires 47K miles on it (bought in 2009)-looks good no cracks.
*ICM original
*Battery year 2010
*found just a little oil in cyl 5 (cyl: 1,2,3,4,6 - NO OIL)
I tested wires and spark plugs:
spark plugs replaced again(new)
I also switched spark plugs wires between cyl 6 & cyl 4 to check wires = still misfire on cyl4, but next week it moved to cyl 5?
Is it ICM? is it injectors? or something else.
It started around 12jan2014 - and every time I got misfire I VAG it - copy codes and clear them. It happens not everyday - please see below.
12 jan 2014
Address 01: Engine
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D04
Coding: 06251
Shop #: WSC 06335
5 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
P0300 - 35-00 - -
P0304 - 35-00 - -
Readiness: 0000 0000
11 feb 2014
4 Faults Found:
P0300 - 35-00 - -
P0304 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
16690 - Cylinder 6 Misfire Detected
P0306 - 35-00 - -
11 feb 2014 (30miles later same day)
7 Faults Found:
P0300 - 35-10 - - - Intermittent
P0304 - 35-10 - - - Intermittent
P0306 - 35-10 - - - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-10 - - - Intermittent
12 feb 2014
+50miles misfire again
4 Faults Found:
P0300 - 35-00 - -
P0305 - 35-00 - -
16 feb 2014
+300miles later misfire again
2 Faults Found:
22 feb 2014
+400miles later misfire again
spark plugs replaced (new)
spark plugs wires switched between cyl 6 & cyl 4 to check wires = still misfire
5 Faults Found:
P0300 - 35-00 - -
P0302 - 35-00 - -
P0306 - 35-00 - -
26 feb 2014
+350miles later misfire again
2 Faults Found:
Little info:
*ICM original
*Battery year 2010
12 jan 2014
Address 01: Engine
Coding: 06251
Shop #: WSC 06335
5 Faults Found:
P0300 - 35-00 - -
P0304 - 35-00 - -
P0300 - 35-00 - -
P0304 - 35-00 - -
11 feb 2014
4 Faults Found:
P0300 - 35-00 - -
P0304 - 35-00 - -
P0302 - 35-00 - -
P0306 - 35-00 - -
7 Faults Found:
12 feb 2014
4 Faults Found:
P0300 - 35-00 - -
P0305 - 35-00 - -
16 feb 2014
2 Faults Found:
22 feb 2014
5 Faults Found:
P0300 - 35-00 - -
P0302 - 35-00 - -
P0306 - 35-00 - -
26 feb 2014
2 Faults Found:
SteveK-OO (MN)
12-15-2008 05:04 AM
cparke
08-16-2008 04:47 PM
Sir Shnike
01-09-2007 11:14 AM
