When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Got the PO1296? Having a tough times with warm startups? Try this!!!?
Originally Posted by lewismug
Thanks Guys! You probably saved me several hundred dollars! The temp sensor did the trick!
I know this is an old thread but Im not asking a question here... Im stating a fact. I was having problems with restarting my car after the engine had reached operating temperature. Got code PO1296 and after digging up a few posts I found this to be the trick. Replacing the coolant sensor on my 2000 A6 Quattro AWD with 4.2L. worked =D So Im bumping this post back to the top in hope that it helps someone else. Good luck!
