2001 a4 quattro brake light warning light
Every time I hit the brake the brake light warning light goes on. Obviously checked all the lights to see if they functioned. The front turn signal also blinks whenever i apply brakes. When I turn on headlights the high mounted light turns on as well. Please help the beeping from the warning is annoying the hell outta me.
Well the little tail light circuit board, the thing all the bulbs push into, in the tail lights are known to cause intermittant on off warnings. Also if you put the wrong bulb in, say a single filament bulb into a socket designed for 2, it will cause all sorts of funny things.
Good for you, I'm still figuring out mine, I replaced my tail light with euro style led light, since then it is giving problem. I read somewhere that Led light is not compatible with the CAn Bus. But I noticed as well that the auxilliary brake light on the rear seat is blown out I'll try to replace this tomorrow, hopefully this is the problem.
marstonhouse
04-10-2010 02:28 PM
usmcB5
04-19-2009 08:06 PM
ubberwagon
Audi allroad
06-20-2008 06:18 AM
The Chef.
13
12-19-2004 11:22 AM
