Is 245/45/17 doable on 8" wide wheels for 25.5"F 25"R heights on my '01?
St00pid Kumho doesn't offer anything smaller in their V710 R-Compound tire for a 17" wheel...
they came closee in the rear to the curved part of the hub housing, so a 245 with same aspect ratio wont work I dont think, unless you really spaced em out, I was runninga 17x8 with ET35. do they make 245/40-17? that'll be really really close in diam. to a 225/45-17, just wider, wich will likely fit, a few peope have run em i think.
where the hub housing comes up and curves outward, its probably only a few mm's, going from 235 to 245 as you know will not only increase width, but diameter, you may run into problems...spacers might help though, but then again, your going wider, so you may stick out too much.
but basically 245/45-17 is off by a considerable amount. Thats a popular mustang size.
Beergoggles
06-06-2008 06:57 PM
Stage-3-Emre
Audi Original "S" Cars
19
04-26-2005 08:08 PM
808Guy
17
03-29-2005 01:23 AM
