30v valve cover gasket replacement...
Anyone got an estimate on how long it'll take me to replace my valve cover gaskets? I swapped my spark plugs last weekend, and there was 1/4" of oil in each spark plug socket that had leaked down from the valve cover gaskets. Real pain in the @ss, as the oil, of course, fell into the cylinders when I pulled the plugs, and I had to burn it off.
Anyways, I need to replace gaskets on both sides, and I'm wondering how long I should reserve for the job.
<center><img src="http://i28.tinypic.com/doqhcg.jpg"></center><p>I figure on about 1/2 a morning by the time I clean, degrease, and dry off the covers. Ours are slighty easier since I keep the covers off(in pic).Use a some kerosene to soak the covers in(remove coking/oil/grease) , then hit them with brake clean. You might consider changing out the pcv and suction valve in there. Your probably getting higher then appropriate crankcase pressures, especially at the top end.
