30v - Where is the Cam Position Sensor (CKP) / Hall sender?
My garage is really tight and I cant get a good look under the car, a picture would be perfect but if anyone can describe what it looks like that would be nice too. I've been using a mirror to look around and found a black plastic ring above the oil pan on the driver's side connected to the engine via what looks like a rusty 10mm hex bolt but there are no wires leading out of it. Isnt it supposed to be a sensor?
hole for inserting the crank lock tool. The black plastic is just a cover.
The cam postion sensors are up top. The passenger side sensor is right behind the cam spocket in the front and the driver's side cam position sensor is at the rear of the driver's side head. Both run directly off the intake cams.
c4S6
Audi Original "S" Cars
05-01-2007 02:19 PM
Texas Twin T
09-13-2004 11:15 AM
