is the 3rd brake light supossed to be on when the headlights are?
Guest
Posts: n/a
...i would like it if the third brake light flashed whenever the ABS was invoked to mimic flashing brake lights as if you were pumping them yourself. not just in my A4, but in other cars i've had with ABS, i've come to controlled stops on slick surfaces only to have someone barreling down on me from the rear. all they see is steady lights and a steady stop even though my ABS is flailing wildly. i've just about run stop signs because I was afraid to stop for fear i would be rear-ended. i'm thinking that, short of doing a donut, a flashing brake lamp would at least clue in drivers behind you that something is amiss on the road ahead of them.
just a thought to think about. ABS 5.3 is kick ***, BTW =)
Guest
Posts: n/a
I changed a bulb in my tail light and i noticed that the third brakelight was on when i turned the headlights on .. i pushed the brake and it got brighter... i don;t think this is normal becasue i have never noticed it before.. what could be wrong?
Guest
Posts: n/a
...in which case it should activate with the left and right brake lights. Just to be 100 percent clear, "third brake light" refers to the one in the lower center of the rear window on the rear deck of the A4 sedan, and along the upper edge of the rear window in the A4 Avant.
This should not be confused with the rear fog light, which is located in the left corner rear light assembly only, and comes on when activated via the switch on the dash along with the front fog lights and the headlights.
