4000 rpm @ 60mph
Old 02-06-2012, 02:22 PM
kwilson.90's Avatar
Default 4000 rpm @ 60mph
I recently purchased a 1997 Audi A4 quattro. Its a 2.8 with a manual transmission. When I'm driving in 5th gear at 60 mph my tachometer reads 4,000. This can't be right... suggestions?
Old 02-06-2012, 02:37 PM
turbo510's Avatar
I've heard that sometimes the instrument assembly is switched from a 4-cylinder car, and without recoding, the tach will read 50% high. The gearing is different, but for comparison, my 2.8 automatic turns just under 2000 at 60 mph.
Old 02-06-2012, 03:17 PM
kwilson.90's Avatar
Is there a way to test this or recode?
Old 02-06-2012, 04:22 PM
5v/cyl's Avatar
Need a VAG-COM.
Old 02-06-2012, 05:08 PM
GTA_Driver's Avatar
Needs recalibration.
Old 02-07-2012, 04:45 AM
kwilson.90's Avatar
I hate to sounds ignorant, but what needs re-calibration? Is this something that a mechanic needs to do?
Old 02-07-2012, 05:56 AM
GTA_Driver's Avatar
It could e that the cluster is coded incorrectly, in which case you need VAG-COM, or a dealer, or an independent Audi mechanic to log in, and make sure the cluster is coded for 5-speed, V6.
It could also be that someone took the cluster out and disassembled it, put it back together and didn't recalibrate the needles. Some used car dealers do that to put a tape over the check engine light.
When you turn ignition ON, does your CEL come on?
And finally, it could be a faulty engine speed sensor.
Old 02-07-2012, 08:52 AM
kwilson.90's Avatar
The check engine light comes on when I turn the car on, but it does not stay on after I start it.
Old 02-07-2012, 09:41 AM
GTA_Driver's Avatar
You need VAG-COM then to connect to the cluster and either 1) code it right, or 2) calibrate it.
Old 02-07-2012, 10:11 AM
turbo510's Avatar
You'll want to get a VAG-COM setup anyway for maintaining this car, so this tach issue is a good reason to do it. Changes to the car's programming require a licenced copy, was about $99 last time I checked. You'll need an appropriate OBDII interface cable too for your computer. Believe me, you will save plenty in the long run.
Quick Reply: 4000 rpm @ 60mph
