96 A4 2.6 No Injector Pulse
I have a 96 Audi A4 2.6 Engine Code ABC, Engine Cranks begins to fire and then just continues cranking. Fuel Pump is Ok and has correct fuel pressure, Spark is good, engine will run on Aerostart and will continue to keep running while you continue to spray Aerostart into the induction tube. Noid lights detect initial brief injector pulse and then nothing. No Injector pulse while cranking. Injectors have power at all times, return circuits from injectors back to the ECU are all good. What have I missed and what could be the possible cause for this problem. Thanks Jon.
I got the same problem with my 2004 a4 Quattro
Sent from my iPad
I replaced the fuel pump And filter, replaced The pressure release valve on the fuel rail because It started to leak... I put it on the computer and it read injector one when I looked at the wires they were both cracked... I fixed the wires reconnected them with heat shrink tubing.... Now the injector Harness has power like it's supposed to but still fuel pressure Is there an spark..I Then replaced that relay You know the J17 relay I've got nothing left now my new fuel pump is starting to hummm And buzzzzz... I'm losing my mind... Thanks for your fast response before
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
Speec
10-06-2015 07:30 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-24-2015 12:06 PM
Im@wesome~ out!
09-23-2015 08:18 AM
