96 A4 2.8
Re: well the value of the non quattro is a good deal less, but that can be used to get the car chea
I'm not sure if the 96 has any particulars that I need to be reaaly careful with
Are you sure you want the 12V 2.8 engine?
The '96 A4 came with the 12V 2.8 V6 instead of the more powerful 30V 2.8 V6 that came in latter model years. I always thought the performance of th 12V engine a little sluggish, while the 30V engine is quite satisfying. There also isn't much in the way of performance mods for the 12V engine.
The '96 2.8 is still a nice car, but if performance is important to you, a '97 1.8T offers a lot more options.<p>- Rog
<a href="http://registry.audiworld.com/audi/registry/details.asp?car=1565"
<img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/toblastco.jpg" BORDER=0></a>
'99 Silver A4 2.8QMS
'01 Imola S4 Avant (No. 5 on the waiting list)
I had a 96 A4 2.8...
.. and it was non-quattro. I turned it in after its lease expired. Maybe you're buying my old car?
I cannot think of any major problems. Only that my power steering fluid all leaked out once because of a faulty hose. The dealer fixed it, but I hear this happened to a lot of A4 owners.
Also, some of my plastic panals became slightly loose because the fasteners failed; one under the engine and one in the rear wheel well. No big deal to have fixed.
One minor thing is that the cup holder mechanism eventually became inoperatable, because of all the dust and dirt that got into the plastic gears. That's OK, because even when it did work, your cup would always jump out when your turned sharp corners.
Good luck with your purchase.
I was just talking to a guy from ottinger the other day...if you plan to modify it later on
if you want to chip after you get your car go for a 1.8 turbo. He says that the V6 engines dont benefit much from chipping and whould need lots of engine modifications to gain any benefit from the chip(ie cost lots $$ more to mod) . And the 1.8 has more possibilities of different engine mods than the V6
but then again the 2.8 already has plenty of power for everyday use if you dont want to make any changes.....<p>=================================== =====
Audi A4 2.4 V6
FWD Tip shift
no.. it's not avaliable in the states..
Audi A4 2.4 V6
FWD Tip shift
chewy d
04-23-2002 10:18 AM
T-28-Quattro de VT
05-22-2001 05:33 PM
