96 A4 2.8L Quattro - Transmission Fluid Change - where to fill?!
#11
Well I definitely put oil in until it was overflowing before I started the car. And I kept putting oil in until the fill was overflowing before I shut the car off. I put the plug back in right away. The oil would not drain from the torque converter that fast, but yes some oil did start to come out before I put the plug in. Not enough that it drained a ton out. I think I just don't have enough fluid in there to start with... I'll have to try again in a few days... too busy tonight!
Thanks for all the help. I need to get a better "pump" situation.
#12
It's not just the torque converter. It's the rest of the tranny. That's why they have you put it in every gear before you test for ATF level. I've done this one....way too often (I rebuilt mine). To start with the ATF cool enough, you almost have to leave it overnight. Go through every gear, then wait till the ATF temp is 35 - 45C. If it doesn't trickle out at 35C, pump more in. When it trickles out, DO NOT stop the engine. Put the plug back in....then stop the engine.
#13
Just my .02 though
#14
At 122k, you are past due on a fluid and filter change.
#15
Not sure if that's accurate.. .well there's conflicting info. Bentley's website has the ATF fluid being changed a number of times and Audi says it's a lifetime fluid. I'd replace the filter and fluid to make sure all the metal shavings are gone. ..and you get more lubrication.
#16
#17
If it never needs service, why does it have a drain plug?
#18
LOL. You mean a "sealed unit" just like the engine? It's only a "sealed unit" when you seal it with the plug...just like the engine. Don't fall for the Audi party line. Just link any mechanical component, your trans requires service...it's no different from the engine.
#19
It's illogical that your ATF is "lifetime" - all fluids break down plain and simple! take your ATF to a lab for analysis and check if the fluid is acceptable. Is the color brown or clear? Why's the color black when the trans is sealed? Are there metals at the bottom of your pan? Is there sludge? What happens to your trans when there's metals in the fluid? Does that accelerate your trans from breaking down and is it abrasive?
What does ZF state for fluid change?
Also Audi states your diff gear oil is lifetime. Change it and see how your car rides, I bet it's smoother, MPG increases and your gears will be lubricated once again. When you drain your diff gear oil . .is the color black or clear? If it's sealed why is it black?
https://www.audiworld.com/forums/sho...php?p=15458861
#20
