97 A4 2.8 v6 12valve unable to connect ODB II
When I took my car to get an inspection my ODB II connection would not work. i noticed that my Odometer is not lit anymore but it still shows the mileage if I look closely with a light. I checked all the fuses that I know of but still no luck with getting it to connect.
Has anyone ever ran into this problem?
The most common failure is the ABS module, it's not uncommon for a failure to block the OBDII connection. Try unplugging the module under the hood.
Any of the modules in the car could be locking you out, cluster is definitely possible.
maaliish
02-15-2001 03:15 PM
Dead
08-01-2000 08:39 PM
