'97 instrument cluster screws won't budge
After searching around here I bought several mini bulbs online (orange base) and was planning to replace a few that have burnt out. My problem is that I can't remove the two screws above the steering column that hold the cluster in place. They won't budge! I've tried several screwdrivers, a ratchet, an electric screwdriver (with some pretty decent torque too). Nothing.
Any suggestions on how to get them loose? It's also a very tight area to work so large tools won't help. Any help is appreciated. Thanks.
-Will
-Will
Keeper of the Cash
Superman himself torqued them down
Don't give up, they'll come out eventually. However, once you get them out and reinstall the cluster, you'll quickly figure out why they were so damned tight.
*squeak squeak*
*squeak squeak*
I have two audis, one of them the cluster came out fine but on the other I've got the same thing going on; one of the screws came out fine and the other won't budge and I've put the hurt on it. I may have to drill it out of there.
And I have no idea what Nate meant when he said "However, once you get them out and reinstall the cluster, you'll quickly figure out why they were so damned tight." Nate- is it a secret or do you maybe have some useful information you could share?
Luxus Panzer
04-12-2004 02:58 AM
Stang Guy
12-18-2000 06:22 PM
