98 a4 2.8 power steering fluid???
just wondering if there something else I can use and get in my town there no audi dealers here its says it wants minurl hydrolic fluid is there something else I can use I can get from Canadian tire or something
Still, use non-specified fluids at your own risk, as your experience might end up differently than mine with the CS Turbo.
Absolutely 4Driver, if this was a tongue-in-cheek post, I'd wouldn't have justified it with my CS Turbo story. So if you've seen a steering system get ruined using the Prestone PS fluid, by all means let me know so I don't advise this again. It's just that I'm a pragmatist when it comes to things like ATF and hydraulic fluids. Pentosin is a "mineral oil", an old-fashioned term for petroleum-based oils that come from the ground, as opposed to vegetable oils or animal oils. Prestone PS is a "mineral oil" too, mixes with Pentosin, and worked out for me.
But as I made clear- "use non-specified fluids at your own risk, as your experience might end up differently than mine with the CS Turbo"... and "If you are absolutely stuck..."
Most European cars use the more expensive fluids.
Last can of Pentosin I bought was under $25. Try the VW dealer instead as they use the same fluid.
My local O'reillys has it for $22.
If you can't afford that, I recommend a bus pass.
zardozrdr
03-16-2005 10:38 AM
Mark.core
08-05-2004 02:54 PM
odj
11
03-15-2002 08:11 PM
vrsix
01-30-2002 04:37 PM
