98 AEB- where is the MAP sensor (G71) ?? AKA Bar Pressure Sensor
...is it in the ECU box, i dont recall it being there last time I had the ECU out.
Reason: 16491 DTC.
Bentleys page 24-131 is useless.
Reason: 16491 DTC.
...I did notice the VAG sez: (G71/F96) signal too low. And the CEL did fire after the 2nd warm run like it should. Ill check F96...unless, of course, someone beats me to it!!
17951 / 16506 / 16491 / 17593 all 35-10 Intermittant. (bix thx to Mike at chicago GTG for helping with the VAG last nite!!)
Maybe dbl check that the ECU is fully plugged in (both harnesses) and that you have run a good TBA post checking the plugs. That 'list' reads like a wiring problem more than that the O2 sensor, TB and Baro sensor all decided to crap at once .....
I did recently unplug the ECU (to test crank the starter with no belt load on the motor) and Im sure I plugged it in securely, but ill also check again, because xxit happens. I also cleaned out the Throttle Body which hasnt been cleaned for 100K miles!! I also unplugged alot of sensors around that area. That was probably 3-4 weeks ago. Almost too long??
Also, found info in bentley, that sensor is in the same place as the MAP (well, i hope so, it only shows ATW motor code!!)
BTW - Thanks Yips!!!
IIRC the BARO sensor is located in the plastic ECU case. Look at Bentley's page 24-2 item number 4:
Electronics box (E-box) with:
Motronic Engine Control Module (ECM) -J220-
Barometric Pressure (BARO) sensor -F96-
there will be a difference with the windows completely close versus open, if you moving 60+mph.
The ECU box has an open passage to the passenger compartment, but is completely sealed under the hood.
I have a spare Baro sensor, email me if anyone is intested.
Vic, 99.5 1.8T APR Stg 1 FWD
allroad(s) lead 2Gavin
Audi allroad
12
08-12-2012 05:58 AM
dtompsett
Audi Original "S" Cars
08-29-2006 02:39 PM
The Librarian
01-09-2006 03:00 PM
Phat_Bastage
08-07-2005 06:25 AM
escargot
12-13-2002 12:52 PM
