99.5 A4 Headlights
Guest
Posts: n/a
I thought the headlights on my new 99.5 A4 didn't go out far enough. I raised the headlights several turns of the height adjusters. Much better light! I get no one flashing at me, so lights must not be dazzling oncoming drivers. These headlights are much better than my 96 A4.
Guest
Posts: n/a
There are white plastic adjusters behind the headlights. The center ones are for the height. The outside ones are accessed through a hole in the metal and are for angle. The adjusters will accept a hex key or a small phillips head screwdriver. I pulled up to my garage (level surface) and moved the light up. I could see the change as I did it. If you go too far, people will flash you. Just try it till you like the light and no one flashes you!
Guest
Posts: n/a
I had the same height problems. I am wondering if the need to raise the lights is more common to sport suspensions?<p>Wondering if Audi needs to Tech Bulletin dealers. I thing the aiming of the projector bulbs is much more critical then older beams.<p>So guys...is yours a 99.5 sport suspension or not!
Guest
Posts: n/a
Actually I'd like to have the lights from my 96 back - these are junk.<p>Go down a hill and try to see beyond the bottom - there is no light vertically upward beyond the cutoof and even after raising them - the high beams have no where near the range of my 96.
mwaites
03-03-2000 06:58 PM
