99 audi a4 2.8 p1626 check engine light advice please
ya i dnt kno anyone with via vag com i checked ecu looks good i delete the p1626 an it dosent even delete when i try to delete it it stil remains there .light stays off for alil but when i scan it it stil there p1626 an my car is 5spd
when i check the ecu there was 2 bolts missing thinging mayb the ecu is bad idk
Transmission codes are not part of OBDII so you are wrong
Buy/ borrow a VAG.com and recode the ECU for manual transmission.
http://img.photobucket.com/albums/v1...ECU_coding.jpg
It's the 4th digit in a 5 digit string.
First two digits
06-US
Next digit
1-FWD no traction control
2-FWD with traction control
3-AWD no traction control
4-AWD with traction control
Next Digit
0-Manual trans
5-Automatic
Next Digit
1-Audi A4 or Vw Passat.
First two digits
06-US
Next digit
Next Digit
0-Manual trans
5-Automatic
Next Digit
Required special tools and test equipment
VAG1551 or VAG1552 Scan Tool (ST) with VAG1551/3 adapter cable
VAG1598/22 test box
VW1594 connector test kit
Wiring diagrams
Hope this helps!
VAG1598/22 test box
Wiring diagrams
Hope this helps!
Most folks doing maintenance on their own cars won't have or need all that factory test equipment to recode the ECU the way AudiMick explained. A diagnostic scan cable, and a computer with licenced VAG-COM does it.
AudiWorld Expert
If one is going to work on their own car this is a must and a cheap tool.
If you post in the local forums either here on AW or the other audi forums you will probably find someone local with a VAG-COM
