A4 1.8T need advice
#11
#12
The stock unit is fine for stock boost or even chipped. If you are running big boost and a more robust unit is needed, buy a bypass valve that recirculates the air into the intake track. Venting to atmosphere is a bad idea. It confuses the ECU.
Unless you are running a program that writes out the MAF and you really like cool noises, you want to stay away from blow off valves.
#13
I read up on this and with stock boost, any blow off valve of any kind is taking away air that the computer expects to be there. Running a BOV would lead to running rich and losing power and efficiency. In my case, the DV isnt working so im replacing it with an oem one.. Thanks for everyones help
#14
Do not buy the Forge Splitter Style Bov you can find on ebay, very cheap and does more harm then good. I bought my A4 in december and someone had tried to make some mods to it by putting the El'cheapo forge noname splitter valve on it, it was hooked up like the factory diverter which is a no no. and after taking it apart to find the pressure cup scored and gauged up, it doesnt hold boost pressure and is very unreliable, even thou its half the price of a Forge unit, its totally not worth buying. Buy only the Splitter R with forge's name engraved in the body of the BOV.
#16
#17
I bought a used a4 98 1.8t. Correct me if im wrong i believe the 1.8ts come stalk with a diverter valve. But the previous owner of my vehicle did a conversion into a blow off valve, and my car has a stalling problem. When im coming to stop sign and i press on the brakes it likes to stall and cut out but it cuts out a lot more when the AC is on. Im just wondering if the set up of the blow off would have anything to do with this? someone help me please
#18
LimitedEdition
09-11-2022 04:53 AM
TT_Power
10-29-2005 08:56 AM
