a4 2.5 tdi and the fuel injection pump control module problem
Hi folks,
I have an audi a4 2.5 tdi and the fuel injection pump control module (j399) went wrong. After I had it fixed (by a specialised garage, they programmed and tested it), I put it back into the car, but it doesn't wanna start. The diag reports 01318 fault (fuel injection pump control module, no communication). The wiring is good. My question is that do I have to adapt the contol module to the ecu? If I do, how (what channel)? If not, then it must be the ecu's can controller, that is bad.
Thank you in advance
Peter
Peter
I'd suggest that you go to the TDI club. You will probably get a quicker response.
Good luck...<ul><li><a href="http://www.tdiclub.com/">http://www.tdiclub.com/</a</li></ul>
rukus5150
02-05-2019 11:32 AM
ludviks@online.no
New Member Welcome Area
12-26-2018 03:30 AM
AudiForYou's 2.7T
08-10-2006 04:09 PM
nemena
04-10-2005 06:44 AM
