A4 - 2.8 Automatic Transmission Problem
#11
Dave,
Thanks for your tips! The gear display, is not working ( the LCD went out, and i am look to fix it or buy a new Instrument cluster), but it seens that is OK. When I move the shifter, and it is hard, but reach the defined position, the gear is selected ( for example R), but sometimes comes with a short metalic noise (like when the brakes are stick ). I will follow your sugestion, check the cable conections and the shift lever base. If I found the solution I will post it here. If you have any other idea, I would apreciate it. Thank you very much.
TenPerfDB
12-18-2003 06:57 AM
Robjared
10
10-17-2002 02:51 PM
