A4 97 quattro automatic transmission oil plug
Old 01-13-2009, 03:10 PM
  #11
maxxrpm's Avatar
Default Re: You don't have a clue what you're doing, so stop while you're still ahead.
Curmudgeon,Thank you for your concern. I really appreciate. I'll keep you posted.
Old 01-13-2009, 03:16 PM
  #12
Guest
Guest
Posts: n/a
Default Keep in mind that a 1999 would be a Tiptronic auto, you have a regular auto...
So its conceivable that they are different. I could believe that some fluid would dribbling out, if the car isn't level, etc. I assume the only reason you are worried about the trans in the first place is from all the oil leaks visible in the pics?<ul><li><a href="http://www.crapple0.com/bentley/b/Audi%20B5%2097-2001/Transmission/5sp%20Automatic%20Transmission%2001V/37-133%20ATF%20checking%20&amp;%20changing.pdf">This is the correct way to measure the oil level, much more involved.</a></li></u
Old 01-13-2009, 03:34 PM
  #13
Tech Guru
4Driver4's Avatar
And the car must be level and the trans fluid must be in the correct temp range.
Old 01-13-2009, 04:13 PM
  #14
Tech Guru
4Driver4's Avatar
Nice tailshaft seal leak.
Old 01-13-2009, 09:34 PM
  #15
velosouljah's Avatar
Default no fear I say...you only have an auto to *lose*
j/k =)
Old 01-06-2011, 07:48 AM
  #16
maxxrpm's Avatar
Default Updates
Well guys, I wanna give an update to my posting. It was not an easy task being the first time I did that. After trying a few different methodes to push the transmision oil inside from underneath the carriage I have changed the transmision oil by myself and the car is running well with no problems. Car have now 165k miles. Thanks to all that responded to my posting.
Old 01-06-2011, 09:02 AM
  #17
maxxrpm's Avatar
Originally Posted by velosouljah
j/k =)
velosouljah,
no fear indeed, to lose an auto is not the right saying. Break a part is more like it. However, parts are replaceble and my belief is that what was build by man can also be fixed.
RallyAudi
04-18-2008 02:56 AM
DriveMNFixM
07-08-2007 12:03 PM
RallyAudi
05-21-2007 05:40 PM
ebony andras
03-26-2004 12:54 PM
imo46
Audi 100 / A6 (C4 Platform)
06-27-2003 12:08 PM
Quick Reply: A4 97 quattro automatic transmission oil plug
