A4 Brake Pads - Dealer wants $1000 for brake job
Old 09-06-2001, 01:53 PM
Junior Member
summersr's Avatar
Default A4 Brake Pads - Dealer wants $1000 for brake job
A4 with 40K miles. Dealer wants to do the full meal deal (pads, turn rotors, rebuild caliphers, etc,) and charge $1000. Leary about taking an Audi to a Midas or other brake shop. Found the how to change Audi pads in the tech section. Question is where is the best place to buy Audi Pads. Any other advise would be appreciated
Old 09-06-2001, 01:57 PM
SKareKrow's Avatar
Go to goapr.com
Old 09-06-2001, 02:01 PM
Junior Member
Cool Craig's Avatar
Default Please dont go to that dealer, unless its under warranty.
......at 98 bucks an hour its not worth it!!! Mintex Red Box pads, Pagid or Porterfield RS4 are well respected and less dusty than stock or Ferodo (oem) There is also the ability to add the A8 rotors and TT caliper mount to your existing system and still remain well under 1000 bucks. heck, you can get a full front brake set up with fluid, lines, NEW PORSCHE calipers and pads for 1300-1500 bucks. you can get brake system parts from Clair, SPP, AWE, QRS and countless others.
Old 09-06-2001, 02:27 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default Rebuild calipers?? What reason did they give you for this?
People change out their pads and rotors all the time, without "rebuilding" the calipers. Consider another dealer who isn't looking to rip you off.
Old 09-06-2001, 02:32 PM
xr4tic's Avatar
Default Doesn't mean they shouldn't be rebuilt....
Most calipers are extremely easy to rebuild, they just consist of an o-ring and a dust seal. Cheap insurance, and something that should be done, but usually isn't.
That being said, I'm not sure how easy it would be to rebuild the calipers on an Audi. I bet the fronts are easy, but the rears might be more difficult because of the parking brake.
Old 09-06-2001, 02:42 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default Certainly not, but let's hear the reason the dealer gave him.
$1000 is a LOT of work...sounds like they are rebuilding at least two calipers, maybe 4. It's probably overkill.
Old 09-06-2001, 03:54 PM
Junior Member
summersr's Avatar
Default Thanks for the advice.
Have had the same line from American car dealers, expected better from Audi. Have worked on my own cars for years and knew this was BS at 40K. Will use the references you gave to obtain pads. Thanks again
Old 09-06-2001, 04:43 PM
dpd
Junior Member
dpd's Avatar
Default Re: A4 Brake Pads - Dealer wants $1000 for brake job
don't cut rotors.if they are no good.relace them.they can't be cut.why rebuild brake calipers?leaking?dust boots torn?parking brake mechanisims binding/frozen?calipers frozen?if the answer o all of the above is no.go somewhere else.--dpd
Old 09-06-2001, 07:49 PM
Junior Member
Bing's Avatar
hook up a BIRA setup
Old 09-06-2001, 08:14 PM
Junior Member
EricB's Avatar
Do NOT resurface Audi rotors with 40K on them.
Quick Reply: A4 Brake Pads - Dealer wants $1000 for brake job
