A4 bumper inserts to match RS4 grill
Anyone have a tech write up on this? Did a search and found some things. Looking for a bit more detail. Using 3/4-9 expanded steel, Gloss Black Rustoleum, Marine Epoxy and original inserts for mounting.
Thanks for any help.
Amos
Amos
expanded steel will rust. Try galvanized steel mesh. (1 pretty big pic)
<center><img src="http://mysite.verizon.net/kchiang/Images/2003-10-12%20My%20Audi%2006.JPG"></center><p>I found some @ home depot as covers for gutters.
They are really cheap and they turned out well.
I prefer flat black instead of gloss...IMO they didn't look right "shiny"
I also used the lower grill frames after dremeling out the slates.
I used a jigsaw to make my rough cuts and a dremel for the rest. I sanded the metal (dremel) and used an automotive primer before painting. Before adhering to the frames I removed the primer at the contact points (VERY IMPORTANT). I used an adhesive called <i>JB Weld - 4 minute epoxy</i>. It setup faster than a goop or construction adhesive and seems to hold pretty well. I was set in a few minutes but the cure time was about 4 hours. Once it cured (left it overnight) I sanded down any excess epoxy (dremel) and then painted all of it grills and frames, flat black (2-3 coats). I followed with 1-2 coats of matte, clear coat.
Steve2001A4
Canadian Discussion
07-27-2004 06:50 AM
simply J
12-18-2001 10:23 PM
Has anyone replaced the lower plastic grill on there bumper where the fogs are with something ..more
PuRe A FoUr
04-21-2001 07:01 PM
