A4 stalling .
Old 06-28-2013, 12:47 PM
Roller's Avatar
Default A4 stalling .
I posted about my A4 2.8l stalling I changed the crank shaft sensor,engine coolant sensor,cleaned the EGR and throttle body. Then I took my fuel pump out on the top part that mounts to the tank there's 2 plug ins I noticed the posts were corroded I cleaned them now my car runs great is this a common thing? I have had my 1997 A4 2.8 for 1 month.
Old 06-29-2013, 09:21 AM
turbo510's Avatar
Contacts corroded inside the tank? I wouldn't think that is common.
Since you have found some corroded electrical contacts, expect that there must be more. A standard thing that I do, at least every couple of years when doing the brake fluid and air filter changes, is to disconnect every electrical connector that you can reach. Spray the contacts with WD-40 or similar contact cleaner. You might avoid problems with O2 and MAF sensors this way.
Old 07-09-2013, 04:42 PM
Roller's Avatar
Ok now my car runs great till I come to a strap incline then it cuts out or sputters. Fuel pump ? Relay,filter any ideas ?
Old 07-09-2013, 08:04 PM
turbo510's Avatar
Steep incline? If that is what you meant, loosing power under load might be a high resistance (clogged) fuel filter, etc. But get it scanned because there might be a clue in the ECU.
Old 07-15-2013, 11:34 AM
Roller's Avatar
All it says is EGR insufficient flow. But the EGR and throttle body hae been cleaned
Old 07-15-2013, 05:04 PM
AudiMick's Avatar
How did you clean the EGR, did you remove the throttle body and the EGR valve?
Old 07-15-2013, 09:25 PM
turbo510's Avatar
I just did mine last weekend using the wire cable in a drill technique. I think I'll do the smog check tomorrow, rediness is OK, we'll see.
Old 07-16-2013, 08:37 AM
Roller's Avatar
I took the EGR off with a 10 mil socket and a 2il crows foot then used intake cleaner and a cable to clean the port on the throttle body.
Old 07-16-2013, 12:22 PM
AudiMick's Avatar
Maybe you typed that incorrectly. The blockage is not in the throttle body.
It's where the EGR passage in the manifold makes a 90 degree bend vertically.
All the crud collects in there, takes a while to dig it all out.
Old 07-17-2013, 09:04 AM
Roller's Avatar
That's what I ment . But today I put a new fuel pump in and drove it. On flat ground it ran fine on a upgrade it acted up again. I'm running out of things to replace. I did crank sensor, cam shaft,engine temp sensor,cleaned EGR and port,cleaned MAF sensor. New fuel pump. Only thing I can think of is fuel filter.
Quick Reply: A4 stalling .
