ABS engaging at low speed
I have searched this forum quite a bit regarding the ABS coming on at low speeds. My particular issue is the vehicle engaging the ABS at around 10 km/h. If you go above 20 km/h and then brake, you can replicate the issue.
You can feel the pedal becoming softer, and pushing farther down, and then the ABS will pulse just as you come to a stop.
I have a run a VAG on the car, and the ABS was diagnosed as not having any faults. The wheel speed sensors are reading the exact same speed all the way down to 0. However, the VAG disconnects if you go above 21 km/h. So it is fairly difficult to replicate the problem with the VAG connected since you have to get the car above 21 km/h to make the issue reappear when you brake.
I had an upper control arm replaced on the drivers side front, and that was the only work done. I noticed that the wheel speed sensor was not pulled out.
Since the sensors were not touched, it shouldn't be a seating issue.
But the ABS problem, did surface directly after the front control arm was replaced by the shop.
Has anyone figured out what actually is the cause of this problem if their is no ABS code and no sensors pulled out?
Interesting. When I look at the sensor, it really does not look like the tech pulled it out, I mean there are no marks on it from prying it out with a screwdriver, or really anything to indicate that it was touched.
When I went to take a look at it, I was really sure that I would have found that it was loose, or that it was not seated properly.
But the sensor is so tight in its socket, that it seems that it would be easy to pop out, had it been worked on.
Does the sensor need to have a tool to pull it out? I tried putting my fingers around it, and pulling but it was really in there.
abs wheel sensor was not pulled out.
it is not loose, and the wires are not stretched.
I guess it is just coincidence that it started acting up after the control arm was replaced.
The ABS light is not on, and there are no fault codes in the ABS. All the wheel sensors are registering the same speed right through to a stop.
I am at a loss. What can it be? Would it still be a faulty wheel sensor, and I just need to replace it?
