abs wiring/controller questions
Old 05-23-2010, 04:08 AM
waspie's Avatar
Default abs wiring/controller questions
recently got an a4q 2.8 1998 and of course it had the dreaded failed abs module. the other day at the JY i got a module of a 97 or 98 passat and plugged it in and low and behold it shows up in vag-com. the problem is it says my rear right wheel sensor is bad (open or short) but the multimeter reports 1200 ohms all the way to the front right at the connector with neither pin shorted to ground or B+. is the passat controller expecting wires to be in different places or even though the sensor tests fine via MM could it be a problem?
thanks
Old 05-23-2010, 08:13 AM
mtroxel's Avatar
You could swap sensors with another wheel. It's not that big of a job. Follow the cable to a grommet in the wheel well, pry that out and there's a plug behind that.
Old 05-23-2010, 11:10 AM
waspie's Avatar
I thought about jjumpering the right to tbe left and left to right to see if the code moved. Anyone have the pinouts for a 98 passat and 98 a4?
Old 05-24-2010, 04:49 AM
waspie's Avatar
I *think* i may have found an answer. after a lot of searching i found an abs wiring diagram for a 2000 that *probably* still applies. it *looks* (if this diagram is accurate) like G44 (rear right sensor) is wired to pin 1&2 of a 'quattro' controller but in a FWD model G44 is wired to pin 1&3. Assuming there's no insane reason why i shouldn't move pin 2 to pin 3 i'm gonna give that a go later on when i get a chance.
Old 05-24-2010, 05:20 AM
Tech Guru
4Driver4's Avatar
A quattro controller will not work in a WWD car.
Old 05-24-2010, 05:33 AM
mtroxel's Avatar
I was just talking about the ABS sensor. Those are interchangable aren't they?
Old 05-24-2010, 05:52 AM
waspie's Avatar
i would imagine. both these things i will try but i have very little free time lately but at work lots of time to search on the computer. gives me time to brainstorm and gather ideas until i actually have a chance to try something
Old 05-24-2010, 06:10 AM
Tech Guru
4Driver4's Avatar
Yes. Even if the plugs are different.
Old 05-25-2010, 02:28 AM
waspie's Avatar
well, i got a chance to try my idea (no offense mtroxel, but like i said it metered out fine at the connector) and BAM the abs light is out! i *understand* that there's got to be some difference between the FWD & 4WD module otherwise there wouldn't be a 1 wire difference but my LIGHTS are out and that f-ing beeping is gone. This gives me time to continue searching the local pull-a-parts for a more relevant module. And, maybe there really isn't a difference, it'd be nice to know what changes from one module to another. This is the module off of a 1998 VW passat v6.
Old 05-25-2010, 02:41 AM
Tech Guru
4Driver4's Avatar
ABS is a critical part of the quattro system. The WWD units do not have the electronics to run quattro.
Quick Reply: abs wiring/controller questions
