Is it absolutely neccessary to use the Audi brand gasket sealant when doing the Cam Chain Tensioner?
And also, does anybody know what it means to "rock the car in first or second to align timing marks on cams"? Sorry for all the posts about the cct, I am just a bit nervous messing around with the cams.
Will the cams rotate freely without interference from the pistons?<ul><li><a href="http://www.ca-va.org/tech/camtensioner/index3.html">CCT writeup</a></li></ul>
I believe I used red RTV, where needed. With the car in gear, when you gently rock (push) it fowards/backwards, the cams will rotate by just a hair each time.
<img src="http://images12.fotki.com/v2/photos/4/48510/3069015/P1080058-vi.jpg">
And no they won't slap the pistons, so long as they're still aligned properly!
Andy
Andy
The marks on the exhaust cam side arent supposed to match up exactly with the chain, correct?
Also, how do you like your vogtland c/o's? I am debating picking up a set... Have you used them on the track yet?
I'm not sure I follow....why wouldn't the marks on the exhaust cam line up exactly?
I actually have Vogtland springs + Koni shocks -- no coilovers. Good luck!
Andy
Andy
78silversc
75
01-30-2013 04:33 PM
TimO'Brien
03-08-2009 10:31 AM
AEBlessed (1.8G)
1.8T Discussion
07-31-2007 05:57 PM
Catamount90
04-29-2007 01:02 AM
