AC problems... i get air blowing in, but it is not cold... its basically running like a fan..
mine was blowing hot and when i brought it to the dealer it needed some big time work done, luckily it was under warranty.
The climate control uses the temperature readings from the sensor in the instrument panel between the radio and the climate control and the sensor in the headliner light panel to determine whether it should blow cold air. My experience is that those sensors don't do a very good job of measuring the temp I'm feeling or that I've set in the climate control.
YMMV.
If it won't blow cold no matter where you set it, start here:<ul><li><a href="https://www.audiworld.com/tech/int5.shtml">https://www.audiworld.com/tech/int5.shtml</a</li></ul>
YMMV.
Mr.Debo'sS4
05-01-2006 02:24 PM
carfan87
07-28-2005 04:54 AM
bostonquattro
10-07-2002 05:06 AM
Potomac-Greg
10
03-07-2002 07:30 AM
