Adding Keyless remotes
I have a 96 A4, it dosnt have factory keyless entry as far as I know as it has an aftermarket alarm, but I dont like the alarm, and I would prefer to just carry around 1 key instead of the key and remote, is there an upgrade that you can do to implement the flip key/remote system or aftermarket, or am i pretty much stuck with wot i got?
thnks
thnks
the vacuum pump in the side of the trunk and a lot of time to figure out how it is different from the stock one and if it can be adapted... or if you need to modify the harness etc etc etc.
the pump module is 8L0-862-257-n $477
you will need to replace all of your keys and lock cylinders. part no. 8d5-898-375 $365. that is without any remotes...
remotes ate 4d0-837-231-t-01c and are $75 each
folding keys for use with remotes are 4d0-837-246-b-roh and cost $69 each
So figure its going to cost a max of $1200 in parts...
try car-part.com
you might be able to locate a 97 or 98 A4 that you can get the lock cylinders from and the vac pump... plus the keys for those cylinders.
This is something for somebody like me to attempt... unless you are experienced at modding and are very good at sourcing parts, I'd say forget it.
4Driver4
11-24-2014 02:59 AM
xcabin84
11-21-2007 09:54 PM
Alan Twigg
05-04-2000 03:42 AM
