Adjusting wastegate actuator on GT28RS
Before I remove the clip and the rod, how hard is it going to be to reattach the rod to the turbo housing?
I'm guessing it's going to be under some pretty strong spring tension, right? Is it possible to pressurize the actuator somehow to make it easier?
<img src="http://pictureposter.audiworld.com/3484/turbo030802.jpg">
It needs to be about three turns tighter to return it back to where it was before I started messing with it. To adjust it the first time the bumper came off etc, and then the front housing/bracket was rotated. Unfortunately, those threads are now nearly stripped so that option isn't available. In fact, I see the bracket is a bit loose in this picture. It's been bent a long time.
But it was pumped up "a lot". What pressure will it need to move the rod? Figured it would only need 10-20 lbs.
exhaust housing. I don't think I would have been able to get it on without it. It was very hard to get in there with my T28 setup just from reaching down from the top. The little clip that holds it on is missing so it will probably pop off again soon.
