AEB randomly stalls when clutch is depressed
When driving the car, it randomly stalls when coming to a stop with clutch depressed.
Idles around 900rpm (tach) or 850rpm (vagcom)
Idle Vacuum is around -.8 bar
Checked coils and spark plug.
Cleaned maf
When I press the gas pedal slightly while in neutral and release, RPM will bounce from 800 to 500rpm a couple of times then settle to 900rpm.
When I remove a vacuum hose (boost gauge / fuel reg) RPM stays constant, when it should, I think, raise to at least 1100rpm.
Is the high idle related to the random stalls? I dont really mind the idle, but the random stalling is annoying when it happens.
Cleaned maf
Constant codes:
17881 - EVAP Leak Detection Pump: Open Circuit
P1473 - 35-00 - -
16989 - Internal Control Module: ROM Error
P0605 -- 35-10 - - - Intermittent
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 -- 35-10 - - - Intermittent
These codes appear once in a while:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 -- 35-00 - -
17973 - Throttle Actuator (J338): Lower Stop not Reached
P1565 -- 35-10 - - - Intermittent
Codes that appeared once and hasn't returned:
17882 - EVAP Canister Solenoid Valve 2 (N115): Electrical Malfunction - This code only appeared once, never returned.
P1474 -- 35-00 - -
17619 - Cylinder Shut-Off: Intake Deactivation Valves: Open Circuit
P1211 -- 35-10 - - - Intermittent
P1473 - 35-00 - -
P1602 -- 35-00 - -
P1474 -- 35-00 - -
UPDATE: replaced spark plugs again (bkr6e) and cleaned throttle body.
Bouncing idle is gone, when gas pedal is pressed and release RPM slowly drops to around 950rpm.
PROBLEM idle is now around 950-1000 rpm (used to be around 900rpm). Vacuum leak I guess.
JacobNeedsMoarMods/$
10
11-11-2008 07:19 PM
mktbully
10-25-2007 11:08 AM
BeeRock::Riding Red
02-28-2006 06:18 PM
