After Auto Rx treatment I get 37mpg!!!!!
Note* Car weights a little less the normal cars, with turbo back, race seats 20lb a piece, no spare (triple A), after market rims 17 lbs a piece. I drive also with 3/4 a tank also.
efficiency increase with turbo back and running K04 with GIAC 5.0 bar fpr
Conditions of driving: LA freeways a bit of small ups and downs. Driving at 65mph no traffic to lite.
With a full fill up costing 50 dollars here - I am glad that i get these numbers.
a bottle. Then there is shipping.
But then when you think about gas costing 50 a tank that isn't that bad.
I follow audi junkie's recommendation with a pre treatment with a kero soak. Did only one treatment.
Car runs quieter, cooler, and smoother.
The engine doesn't make that tacking sound.
The oil temps are a bit lower.
Car is smoother - but maybe a placebo affect because everything has gone so well - no measurable evidence.
My car has 120K !!!! this was its first treatment.
All I can say is i love this stuff.
This item is 2nd on the my list of must haves for the A4.
The 1st is being Trippe A plus (100 miles of free towing.)
is completed! I will look up audi junkies post about kero soak as I am uncertain what that means. I am about 1500 miles until my next oil change, any reason i should not just remove some of the existing oil and add the Auto Rx? I am really broke and would prefer to avoid an extra 50 bucks for the first oil change. So i would remove x amount of oil, add appropriate Auto Rx, drive 1500 miles, then have oil changed, drive the 2,000 give or take miles and change oil again, thus only doing one premature oil change as opposed to one completely unnecessary change AND a premature change.. Thoughts on this approach?
I understand that for "best results" his method is probably the way to go. Would my previously mentioned adding it to oil and driving 1500 miles then changing oil do any good or wasting my time? Again, I understand it is not the best route, but a worthwhile route nonetheless? Thanks
