aftermarket engine internals for AWM engine code.. are there any?
does anyone have a built AWM engine?
I assume its not cross-compatible with the AEB/ATW for anything.
its a bitch, no one used to make rods for our wrist pin so it was cheaper to go with aeb internals (pistons, and forged aeb rods), like i am now, but just last week i find out that integrated-engineering.org has made a rod for our enigne at a significantly lower price than aeb rods, am i pissed very much so, but now i have 1mm thicker wrist pin (whoopdy do) Its completely do-able, internals all have the same specs except for the rod wrist pin<ul><li><a href="http://www.integrated-engineering.org/catalog/product_info.php?cPath=22&products_id=35">clic k for rods</a></li></ul>
although aeb head is bored out more, but its DBW and i am still waiting to see how it tunes campared to nDBW (steve needs toget his done when i do mine)
the bentley lists both engines at the exact same displacement/bore/stroke.
just different sized rods/pistons? will i up the compression ratio with aeb rods/pistons?
