Air Bag Light On-Vag = resistance too high driver side
#12
Never tells you the right things to do....ITS THERE DAMN JOB MAN! GEEZUS....Hence why is costs a TON to have them work on our cars man!
#15
Finally his indy shop found that some spring under the steering wheel was wound too tightly. How, he has no idea.
If all else fails, have a shop check that out.
#17
Check your RADIO controller fault codes. I had the same problem and found a weird fault in the RADIO controller. Something about internal memory fault or something. I cleared it and was then able to clear the AIRBAG fault code. It has stayed off since then.
Try it and let me know.
#20
shouldn't be serviced for at least 14 years. I say keep your 75% freebie for later.
snowchaser
Audi Original "S" Cars
09-05-2011 07:31 PM
constant maintenance
12-01-2006 10:10 AM
metalv8
12-14-2003 04:59 PM
