air filter and water
I did the airbox mod and cut a hole in the bottom of my airbox. I also have the s4 fender liners. What is the danger of the air filter getting wet? What would happen if it did get wet?
the filter will simply flow less air.
But yes water in cylendars = bad.
and you going through a humongous puddle) your MAF will probably be the first thing to go.
I know about water in cylinders. I've wrecked a motor in 1996 when Portland, OR got flooded badly. But do you really think I would get water, not water vapor, into the cylinders. It would have to go through the turbo and intercooler before it would get into the engine.
If you have the AC on you can end up with water in the compressor, happened to me when I hit a 12 inch deep puddle in a downpour. I was lucky no water made it into the engine. The compressor was replaced and insurance covered it but it was not cheap. Normal driving will most likely not be an issue with water.
Brown Water
16
08-08-2016 07:16 AM
adsquare
10-28-2009 02:23 PM
Maini
11-10-2008 03:59 AM
Scuzzy
Auto Detailing Discussion
09-06-2005 12:17 PM
