Air rushing noise
Under WOT i hear this loud air rushing noise i searched the posts and i read all the possibilities, i replaced my BPV a few months ago and i took it out today the the spring feels pretty tight still so i doubt its that and i searched all the intake hoses for leaks by feeling them and i didnt find anything. Did this happen to anyone before and what did u have to fix? what is most commin hose to crack?
well, not exactly. The problem with bad BPV is usually a tear in the diaphragm. What I usually do is compress the spring by pushing the piston, then I place my thumb over the vacuum nipple and release the piston. The piston will move a bit, which is fine. Then, if I release the nipple and the piston moves complete back to it's original position, the diaphragm is fine, but if the piston does not move at all when I release my finger from the nipple, there is a leak in the diaphragm.
That said, it's hard to hear air rushing when there is a leak in the BPV...it's usually a very different sound. I would begin checking all your hoses running from the turbo to the intercooler, and from the intercooler to the throttle body.
jprice@CPS
09-26-2006 05:49 PM
MyKey
11-16-2002 07:00 PM
ivansis
15
11-10-2002 09:25 AM
Avantgarde
08-26-2002 02:01 PM
