For all that have the Stoptech kit. what offset do you have? thanx
Like what Mark said, it's not so much the offset but the design of the spokes. Stock S4 rims have an offset of ET45 and they clear the ST calipers.
AudiWorld Expert
if that wheel will fit over this kit on an A4. The clearance is very similar between the stock S4 setup and the Stoptech or APR kits.
So far, I think most every wheel that fits on an S4 will also clear these kits. Next step would be to ask on the Wheel forum or A4 forum if anyone actually has the combo you want or if they have looked into it.
Do you have a wheel in mind that you are looking at?
Good luck!
Good luck!
You should ask around on the S4 forum. I heard they had to grind the calipers for that wheel to fit. If that's the case then it definitely won't fit over the ST kit.
porsches4ed (APR S3)
12-03-2001 04:43 AM
kev
04-04-2000 04:17 AM
