All right smart guys need your help still...
Old 09-27-2008, 01:25 PM
  #31
Junior Member
Mr Paul [T-28]'s Avatar
Default Messed with Lemmiwinks today.
By turning up the idle to about 1100, and increasing the idle speed torque I was able to drastically reduce the number of misfires. I understand that this is not a fix, but it does help with my sanity some. Now i don't feel like accidentally driving my car off a cliff
I'll post up some logs at idle soon
Thanks again.
Old 09-27-2008, 01:58 PM
  #32
Monkeyboy's Avatar
Default yes, my gauge...it is the 034 one
Per Bentley -
(stock)
At idle: approx. 3.5 bar (50 psi)
After 10 minutes (after engine is off): at least 2.5 bar (36 psi)
I was bleeding off fuel pressure too quickly a while back....causing the car to sometimes not start on the first try. Second try, it always started. Turned out to be a bad Fuel Pressure Regulator.
Old 09-27-2008, 02:02 PM
  #33
RKA
AudiWorld Uber User
RKA's Avatar
Bad TB tensioner or cam tensioner?
Old 09-27-2008, 05:56 PM
  #34
Junior Member
Default Could be?
I am going to change the TB soon, so that will at least eliminate TB tensioner.
FWIW, turning the idle up to 1100 and turning the idle torque value up with lemmiwinks really helped. I know that is a bandaid to the problem, not a fix, but would that tell us any info on what is wrong?
Old 09-28-2008, 10:41 AM
  #35
Junior Member
Default MAF reading at idle is about 3.5-3.8 g/s
Sound OK to you?
Old 09-28-2008, 10:54 AM
  #36
@wesome's Avatar
hell it could be a boost leak at that point :P
Old 09-28-2008, 11:16 AM
  #37
Elder Member
BJC::wokka wokka's Avatar
Default Normal.
Should have asked earlier, but what are the LTFT readings?
Old 09-28-2008, 09:23 PM
  #38
odelay12v's Avatar
Default if you have not tested your vac system and dont have a vac pump..
you can borrow mine i have one of these.. its also good to test individual vac components ..<ul><li><a href="http://www.mityvac.com/pages/products_hvpo.asp">http://www.mityvac.com/pages/products_hvpo.asp</a</li></ul>
Old 09-29-2008, 04:47 AM
  #39
Member
Silver Streakin''s Avatar
basically, the cost of repair is more than buying new. I still don't think I should have to pay.
Johnmalice
30v V6 Discussion
12-29-2016 12:45 PM
eigenvector
06-29-2006 06:05 AM
audibranquinho
Canadian Discussion
02-06-2006 04:11 AM
Marcus Frost
11-01-2005 06:20 PM
01blackS4
04-17-2004 01:11 PM
Quick Reply: All right smart guys need your help still...
