For all that think the AWE KO4 kit comes with a 3 bar FPR
#26
ECU programs require a certain "fueling". With K04 setups, you have a choice as to how you get there.
-the cheapest, easiest way is a 5bar FPR and stock injectors.
-the more expensive, "safest" way is larger inejctors and lower FPR.
think about a hose. if you want to fill exactly 1 bucket with water in exactly 1 minute you could either:
-have a small diameter hose under high pressure
or
-have a large diameter hose under low pressure
the relationship between pressure and max flow rate of injectors is:
<img src="http://www.rceng.com/images/rc/formula-4.gif">
so for equivalent fueling, its either highpressure small injectors, or low pressure large injectors.
it should be clear now
or
d1rt [A4 Pröjekt]
08-23-2007 05:54 AM
trackonly
12-13-2005 05:21 PM
hehateme
33
06-10-2005 10:23 AM
pac1085
06-09-2005 07:14 AM
