alrite so what oil should i turn to/ or keep the same on my HIGH mileage 2.8
I currently have the rather lackluster Castrol from belgium in my 30v and will be switching to Agip in a couple of weeks.
Unless you see below 20 degree starts or so, I'd stick with the 10w-40 HM. The GTX HM 5w-30 is pretty similar to a synth 5w-40 as far as visc goes. Valvoline MaxLife is more normal thickness than Castrol and 20% PAO. Both have stout additive levels.
0w-40
5w-40
10w-40
15w-40
All are good for V6 Audi, choose based on climate and desired OCI. In extreme cold, the 5w-30 GTX HM is do-able. I'm using it in a few cars this winter.
0w-40
5w-40
10w-40
15w-40
<center><img src="http://pictureposter.audiworld.com/27563/visc2.jpg"></center><p>
consumption. Typical 30 weight oil has a High Temp / High Shear (HT/HS) rating of 2.9 and it goes down with use. VW 502/ACEA A3 call for HT/HS of 3.5 minimum.
