Another Airbag Light Thread (yes I searched...a lot)
Alright so I have a 2001 A4 (sold the car in my sig) and a long with many others my airbag light is on. Vag-com reads...
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
So I've always heard about the resistor mod so I figured I'd pick one up and it would fix it, not! So I bought a 4.7ohm 1/2 watt resistor, unplugged my battery, put the resistor in (pic below), plugged the battery back in, plugged in my vag-com and cleared the code, and two seconds later what do you know... air bag light back on, same code. Anyone have any ideas, or did I just make a stupid mistake somewhere? Anything helps, thanks guys.
<a href="http://s57.photobucket.com/albums/g221/michael66899/?action=view¤t=002-2.jpg" target="_blank"><img src="http://i57.photobucket.com/albums/g221/michael66899/002-2.jpg" border="0" alt="Photobucket"></a>
1 Fault Found:
the controler for the airbag is defective. The mod assumes that everything else is working properly and only the airbag is disconnected.
strapping the harnesses before the resistor? I cleaned the contacts, but that wasn't enough, I needed a cable tie or two around the harnesses for those bumpy roads (or passengers who adjust their seats too often.)
I don't know a whole lot about electronics but does that mean I was just off with the 4.7 and I need a 2.7ohm resistor? And how do I know if I need a 1/4 watt 1/2 watt etc.??
TTsumibishi
11-01-2008 08:45 AM
Hokie - STI avant
11
02-11-2005 10:35 AM
