Any opinions on BOV's
Been talking to a couple of guys who say that with the increased boost from chipping the stock valve is no good. The new PES valve sounds good and I beleive that APR has one also. On the other hand I have heard said not to. Ayone with experience with this?
Re: Any opinions on BOV's
APR has always felt that the stock diverter valve is fine and the same with the intake... BOV will make you run rich... and a BOV lets air out into the surface... a diverter valve recycles the air... if you get a BOV... when you let out air the computer miscalculates how much air your taking in and that makes you run rich.... do a search on it.. youll learn alot... later
A BPV and a BOV ARE NOT THE SAME thing...PES valve is a BPV...
it's a sweet valve but $$$$ and I believe it can only be installed one way unlike MC's and Forge and the others.
I've seen the turbo XS valve and it's sweet, but it's designed, kinda like a rifle-bolt.
My valve does not have these problems.
It replaces the stock unit and looks stock. Its a bosch valve rated for more boost. The stock unit leaks past 12 psi. The weak spring lets the diaphram hang open after a shift.
I am up over 250hp with my valve.
Clark
Clark
ersh
01-01-2003 08:29 PM
Jack Wang
01-14-2001 06:10 AM
