Any tips for removing C pillar cover? (with airbags)
Have water stains on the cover. I wanted to remove the cover and clean it, then use a speedometer cable and fish down the sunroof drain, assuming something is clogging the drain causing the leakage. I prefer not to remove the rear bumper which is where the drain exits.
I assume there is a hex screw under the airbag cover and the cover is a straight pull at each clip point. No need to disable the airbag (fuse)?
angelo262
07-09-2017 04:19 AM
quattromano
01-20-2011 08:03 PM
AlanBDahl
02-18-2003 09:11 AM
