When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Is there any way to reset my ecu where i wont end up needing my stereo code?
If you want to clear a CEL, disconnecting the battery on a OBD II car won't work. In fact disconnecting the battery will potentially cause all the learned parameters to be lost and the car will probably actually run worse for a while.
If you need to to clear OBD II codes you need a scanner or a Vag.com, if it's an Audi specific code (non OBD II) you need a VAG.com.
I just wanna know because i have to replace my mass airflow meter, which looks like an easy job, but i would like to know how the computer would respond to it.
You can replace it without disconnecting the battery, don't try to reset the ECU.
Clearing the codes with a vagcom also resets the fuel trim in the ecu and forces the ecu to adapt again.
The car died and there was a fuel tank Integrity issue message read contact shop! Couple weeks previous to event I replaced the under hood fuel pump and cam-follower upper tank filter new module.
I than purchased and OEM upper/lower unit with new tank ring replaced. With codes have been cleared the car started I drove it about 5 minutes and the died the codes below all came up at once. I was recommended too me to reset ECM PCM ?
I This is off of the VAGCOM program 2011 Q5
