Any of you crazy 96-99.5 owners upgrade your cluster to the newer style?
My cluster looks like doo-doo (scratches, etc.) and I want a new look. I assume since my car is older the center display wont work (on the newer cluster). But...assuming Im cool with that, is there anything else that wont work? I think I might go for an S4 cluster...for a change of scenery in the cabin. I believe with the S4 cluster I also have to VAG it to change the RPM ratio's as well. Thoughts/ideas?
96/97 clusters have different connectors than 98.5. I don't know much other than that, perhaps 98.5 and up use the same type of connector as the S4 cluster.
There's highline and lowline versions of the cluster. I have a 98.0 so I'm pretty sure the S4 clusters won't fit even if the harness connectors fit.
Besides, my plastic isn't too scratched up and my trip computer LCD is still sexy.
to time but thats only issue. It just reads your speed at a little bit of a delay. No problem. Probably should watch the road though.
I re-coded it for a 4 cyl to make it with my 1.8t.
I'm not a poser, and I didn't buy it for the S4 logo; i don't even have any S4 body parts on my car. I just wanted to replace my cluster-poxed display, and I liked the white needle with red background gauge look, so I grabbed an S4 cluster.
Get the one for your car with the driver info display. Code it correctly for your configuration and naturally have the odometer set properly.
