Anybody have a wiring diagram for the MAF of a 2001 A4 1.8T
One of my wires came out while i was taking it out (the green/white one with the black wire inside, also has a black rubber shielding tube on it) I searched everywhere but i only found the s4 diagram.. well to make it short does anybody know if the little black wire and the green/white wire should be connected together because i dont know how that goes, i have a CEL and says im running too lean cuz of that now.
pin connections at the MAF connector should be as follows:
#2 should be Green/yellow
#3 should be yellow
#4 should be White/green
#5 should be Green, with a black shielded cable over it. Only the green part should be connected to the MAF, not the shielding of the cable. Did I explain that good enough? If you test #5 it should not be grounded.
#3 should be yellow
beemdubya
08-13-2004 01:15 AM
BLKB6A402
04-07-2004 04:07 PM
BLKB6A402
03-26-2004 12:55 AM
