Anyone have the part numbers for the cam tensioner seal and plug?
Old 03-30-2007, 07:12 AM
Canon's Avatar
Default Anyone have the part numbers for the cam tensioner seal and plug?
I was originally planning on just doing the valve cover gasket this weekend, but another aw member has been nice enough to loan me the cam tensioner tool so i figured i'd try and tackle that as well. Can anyone get me the complete list of parts for this job? I'm heading out to the stealership right now and posting on my phone otherwise i would try and find then myself. Thanks for the help!
Old 03-30-2007, 07:24 AM
Canon's Avatar
Oh yeah, for a 99 1.8t aeb
Old 03-30-2007, 07:29 AM
Carson (K03x2)'s Avatar
Default 058-198-217 $9.13 LIST
That is for the adjuster seal set. Includes the adjuster gasket and half moon seal.
Old 03-30-2007, 07:37 AM
Canon's Avatar
Thanks, and that should be everything for the job?
Old 03-30-2007, 07:43 AM
Default If you already have what you need for the valve cover gaskets, yes.
Its recommended that you use AMV-174-004-01 sealant at 4 locations on the valve cover gasket, but regular hi-temp silicone will do. I've used the white oil pan sealant at those locations as well with no problems.
Also, you should have the T3366 Cam Tensioner compressor before you attempt the cam tensioner seals.
Old 03-30-2007, 07:47 AM
Tech Guru
4Driver4's Avatar
Default AMV-174-004-01 sealant is overrated and unnecessary.
<center><img src="http://www.fotosearch.com/comp/SUE/SUE105/TOCL0153.jpg"></center><p>
Old 03-30-2007, 07:57 AM
Bwhahaha!
Old 03-30-2007, 08:11 AM
WJM
WJM's Avatar
Default tj: Can you lend any help with this?
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2678244.phtml">previous plea</a></li></ul>
Old 03-30-2007, 08:20 AM
Banned
ModifiedA4's Avatar
im working on it...
Old 03-30-2007, 08:41 AM
Tech Guru
4Driver4's Avatar
Sorry. Still a little cranky here.
Quick Reply: Anyone have the part numbers for the cam tensioner seal and plug?
