Anyone here run Kumho tires, size 235/45 R17 on a ET43 7.5" rim...
or similar sized rim(ET 45)? I just got a set of ASX's that I bought online, they're sweet looking tires but they look very wide for a 235. I currently run 235/45 R17 Michelin Pilot Sport but the Kumhos seem wider. I know that the rolling radius isn't the same on these but I like the slightly wider look.
upper control arm in light turns. Nothing a 4mm spacer didn't fix though. The 235's look great and I never regretted buying them even though I don't like having to run spacers.
just like TJHUB said
I rubbed with 235/45 tires on my avus rims which are 17x7.5" and i believe 45mm offset. I am fine with them now with 10mm spacers
if you run at least 5mm spacers you will be fine
will give me enough room!!! I've had no rubbing issues with the 235/45 Michelin Sports but no two brands are alike! You'd think that 235 actually meant 235mm, I guess that's just too simple.
I would imagine that you will rub though, its all about the low offset putting the wheel so far into the wheel well. just get some spacers and you will be fine, will look better with spacers too
SchagenWagen
09-28-2004 07:44 PM
s4rePreSenT`
9
06-10-2003 08:01 AM
