Anyone know how much are OEM S4 side skirts?
$90 a side (the way I did it)
<center><img src="http://pictureposter.audiworld.com/5987/dsc00053.jpg"></center><p>In total cost only about $500 with the paint too. I didn't use all the factory hardware. Just the S4 brackets for the back and the wheel liner skrews in the front. The bottom I used double sided tape that doesn't seem to want to stick. Maybe when it gets warmer it will stick or I will have to put in a few skrews under there. Also used lltek door strips for $150 painted. No sills needed either. They fit over the original ones. Looks like the $2000 version doesn't it<ul><li><a href="https://forums.audiworld.com/a4/msgs/960006.phtml">https://forums.audiworld.com/a4/msgs/960006.phtml</a</li></ul>
Re: Lots... over a G with required hardware
WHAT!!?? Over a G for only the side skirts, that's ridiculous! I guess I would be better off just getting a good paint job on my sides. What do you think?
Re: $90 a side (the way I did it)
Looks Hot!! That's not a bad deal! How do I order them and from where? Do I have to go through the dealer? Do you know the part numbers?
Appreciate your help!
Cost depends on how you want to do it.. it can be done very cheap, or very expensive
Anywhere from around $400 total to about $1000 total painted.
The skirts thenmslves and the hardware to mount just htem is a few hundred bucks. But if you want to make it TRUELY OEM like it is on the S4, it costs about $1000 in parts and painting, if not a few buck more.
I'm not too concerned with the painting just the cost of the parts
I have a friend that owns a body shop who will paint them for me for cost. He does amazing work too!
Thanks for the info!
B_Lumberg
Australia Discussion
02-05-2003 05:37 PM
Quattro Ron in B.C.
10-09-2002 07:54 PM
Imola Ghost
04-17-2002 07:17 AM
